Spin on Oil Filter Torque
Dirtygrunt
Greensboro/ NC
Hey guys I have a spin oil filter kit that im just now getting around to installing and cant find the torque spec. Its from jatonka thanks for any help Dirty
Karl kostman
866
Fargo ND
60 ft pounds for the adapter plates and 1.25 turns of the filter after gasket contact with adapter plate. I would also strongly suggest a nice coating of oil on the filter gaskets prior to installing, you will like them John did a very nice job on this kit
KK
rlwm211
Guilford, NY
Be sure to re-check the torque on your first filter change. 60 FT LBs is correct. the retorque is to compensate for any compression of the gasket over time.
RL
jatonka
87
Ephratah, New York
Karl and Rlwm211 have it just right, 60 FT. LBs. then wait a few minutes, retorque and install filters . Retorque at next oil change, and enjoy. JT out
