Spindle nuts 2 for 8 tabs ok?
taskunitbruiser
51
Alabama
I took off my spindle nut cover and it has 4 groups of 2 slots on the nut, so 8 total slots. I only have tabs bent into 1 group (2 slots) of the 8 total slots. Just to be clear, this is proper correct? I have attached pictures.
What should I use for the gasket maker? Conventional gear oil fine? 75w-90 or 80w-90?
I found the TM for geared hub repair, but it looks different (see pic). I know there is an older style. It specs the spindle cover at 65 lb-ft torque when I am putting it back on.
TOBASH
3,125
Brooklyn, NY
Your images and diagrams are mixing apples and oranges.
Is that a blue hummer diagram?
taskunitbruiser
51
Alabama
only 2 tabs get bent…
either GO work fine, TM calls for 80-90
clean all the surfaces and apply a regular RTV
Thanks!
Some videos on YouTube recommend teflon tape for the drain plug. I will use some loctite on the spindle cover.
Also, if I find some are not bent on another axle I just can tap them down with a screw driver and hammer?
TOBASH
3,125
Brooklyn, NY
Thanks!
Those star washers are 1 use only IIRC
Mogman
8,499
Papalote, TX
Thanks!
Teflon tape is for water pipe, thread sealer is for automotive use.
