DUECE-COUPE
- 5
- 18
- Scurry. Tx
s you can see from my avitar, i bobbed a deuce and made it into what you see there. that being said, i wanted to get the advise of the members on an idea i have to make the truck ride smoother and steer better. i measured the distance from the frame to the floor at the front axle and got 32.5 inches. measured the rear and 34 inches. the truck runs great but sits in what seams like a "jacked up"posture. i am looking to remove the 4 leaf spring plates on the bottom. this will lower the rear of the truck the 1.5 inch difference, and soften the ride as well. i weighed the truck last week and the weight on the front is 6500 lbs and the rear is 4380 this weight is with a full tank of fuel. this will bring the back of the truck down 1.5 inches and change the front axle geometry a little, but i can't figure out how much.
