wsucougarx
- 63
- 48
- Washington State
As far as antenna mounts, you may opt for a one of those fender mounted brackets.
I have not yet removed the window. However, on the exterior the window is held on by a hinge at the top of the frame. This allows the window to be opened for ventilation. So there are only 4-6 screws actually mounted to the van. On the inside, the metal screen and window arm are held in place by a number of small sheet metal screws as well.Mike/wsucougarx,
On a semi-related note, I have some M109a3 questions for you, as I think M109a3 window are a possible good candidate for a transplant to the gull wing.
1) Have you ever removed one of you M109a3 windows?
2) Is the frame screwed in or welded?
3) If you have the time could you gra a picture of the inside and the dimensions of the windows?
4) Does it have shutters to block the light?
Thanx
