Stacking trailers for travel
KaiserM109
SE Aurora, CO
What I'm contemplating might be stupid and dangerous, so if you think so, please feel free to say so.
I just won a bid in Hooks, TX on an M101A2 trailer and am thinking about bidding on another there to make my trip down and back more profitable; I live in the Denver, CO area. The trailer I got is in good shape as far as I can see.
I am thinking about taking the bed off of it and putting the other trailer wo/ wheels on backwards, then putting the first bed in the top one on its side. Then I would stack the wheels from the 2nd one in the bed somewhere.
Another question for 101A2 owners, ‘Does the tongue come off as easily as it does on an A1; what about the brake line from the surge brake?'
KaiserM109
harleyhouse
29
Oakmont, Pennsylvania
stacking is fine, tip them on their tails and strap them together.
tip one onto the wheels without killing yourself and ride it home.
To remove the tongue, two bolts by the spring hanger and pull the tongue tilt bolts in the front. remove the brake line also.
461
Sandyston, NJ
Why take anything apart. Just do as harleyhouse suggested. They will stack fine that way. You can even make some stakes to fit in the pockets to lock them together.
wreckerman893
Possum Connoisseur
15,616
2,008
If the forklift operator is a good guy and the GL site doesn't have a rule against it you can have him turn one upside down and set it up on the other one. As stated above putting some wood in the stake pockets locks them together. Strap them together with some heavy duty ratcheting straps and you are good to go.
jw4x4
Dayton, Ohio
I remember a Triple Stack of trailers leaving the Goergia Rally a couple of years ago. No incidents. Just be sure to secure them, stop and re-check the tension on the straps after you hit a few bumps and they are settled in. Good to go.
kurtkds
-1
Puyallup, WA
That's the way you do it. Love your truck. Service bodies are so useful.
That's NEWFDAD's truck, He drove from Montana to pick up his trailers that I was storing for him that he had won from JBLM.
I believe it was 700 miles one way. LOL
The recovery went without incident.
two.fiveM35
11
Victoria , Texas
Before you try anything, call Hooks and ask if they can assist you with loading. I've made several recoveries at Hooks and have never received any assistance. That place is huge and they have stuff so spread out. I had to move 2 other gen trailers myself so I could get mine out. CALL FIRST
dodgedougak
Joseph, OR
I pulled my trailers individually, from the base in Anchorage and stacked them offsite. A friend had a backhoe and we used that to stack the trailers. I imagine that most any towing or crane outfit would lift the top unit. It took less than one hour to flip, spot and secure using the backhoe. It towed great over 600 miles of sometimes bad and often frost heaved roads in Alaska and the Yukon.
NJRICK
woodbine NJ
GL will not stack or flip trailers anymore. They have for me in the past. Just pick them up one at a time & bring to the closest parking lot. Then stand them on there tailgates & strap them together.
RJM27
26
Burdett NY
Stack M101A2
As said earlier check on and off base, they are not heavy trailers to flip and lift. Also bring a chain long enough to go across the bed diagonally when fliped over, with enough slack to put the forks or another chain. This will help pick it up level to sit down on 2X2's in the 4-corner pockets. I used the 2 side gate holes and the rear holes and drilled a new hole in the front bed lip and secured with bolts.
1,815
Please review the pics from Doug's post #13. THAT IS the proper way to secure these trailers to each other. Stakes in the pockets are fine as are bolts but if you are going to toss some straps, may as well do it right and follow Doug's lead, cross them front and back.
dodgedougak
Joseph, OR
I also swapped a couple of tires around to get the best ones on the ground. They all had good tread, but one was badly weather checked. I stopped early to check wheel bearings for heat and then checked them every time I stopped. I used a set of magnetic stick on lights (12V). Good luck with the recovery!
L999here
South Bend,IN
....M105's
Towed (2) M105 trailers that were stacked over 350 mi. with no problems. Did it twice. Used heavy-duty canvas straps and chains. Used the stakes in the pockets to keep 'em from moving around. It's safe and secure.
