Star washers
cranetruck
75
Meadows of Dan, Virginia
I'm looking for a few good washers (McMasters doesn't have them), hardened, cad plated, internal external tooth, for 1/4, 5/16 and 3/8 bolts.
Perhaps 25-50 of each size.
Anybody know a supplier?
cranetruck
75
Thanks fellows, both Fastenal and Nutsandbolts carry the plain zink coated carbon steel washers, same as McMasters.
I called Fastenal and was told that the cad plated mil-spec washers are available on special order only.
Still looking....
1,123
Have you tried Fastenall? I get all my grade 8 from them they are a chain: We have a few stores nearby let me know if you need me to pick them up for you.
http://www.fastenal.com/web/products.ex?No=20&N=999600101&Nty=0
The fastenal link has obviously changed, the only star washers I see on their site now are:
Lock Washers | Fastenal
RIP David..............................
Link is no longer good. Appears the new link is:
Internal / External Lock Washers: Easy Online Shopping
These are zinc too, no cad plated ones shown.
Hi Bjorn,
These places are both on the wrong side of the country from you, but I've had good success finding odd hardware at both of them:
Olander: The Olander Company Inc: Best Distributor for Nitronic Fasteners in the Silicon Valley
Mr. Metric: http://www.mrmetric.com/
With all the defense electronic stuff out here in Sillycone Valley, there's a good chance they might have what you're looking for.
Good luck!
Olander's website SUCKS, it's an epic fail.
Mr Metric apparently doesn't exist anymore.
Still looking....
So cranetruck, did you ever find a reasonable source for these? I am about to replace a rear harness and would like to use all new washers.
Gracias!
C
steelandcanvas
85
Southwestern Idaho
"Olander's website SUCKS, it's an epic fail."
You weren't kidding, I thought I'd try my luck there, did a search, and came up with a blank page. Not even a "unable to find" message. I'll ask some of my vendors at work, see if they can come up with something. Requests for these washers come up quite often.
1,123
Clinto, I was finally supplied by several goodhearted forum members, ACE and Will Wagner among others...
So does that mean that the mil spec cad plated ones just don't exist, or they are financially prohibitive?
Can the zinc plated ones be used as a substitute for the cad plated units?
Lex_Ordo
Long Island, NY
I have a source. I bought 1/4 and 3/8 from them. I don't have the info on 5/16, but I'm sure they can look up the p/n based on the below information.
Hope this helps. I bought 100 of each.
Starwares
2606-A Aviation Parkway
Grand Prairie, TX 75052
Tel. 972-641-2100
The corresponding part #'s are:
MS45904-68 1/4" internal/external tooth star lock-washer
MS45904-76 3/8" int/ext tooth lock washer
1,123
They have internal and they have external, but not internal/external.
What size fastener are these needed for C?
I think having a selection of 1/4", 5/16", 3/8" and 1/2" would be sufficient. I use these for proper grounding on various electrical projects and I want to use the right stuff (cad plated, hardened, internal/external tooth, etc.).
I may create a thread later today based on this question, but since Lex was nice enough to provide these part #'s, I have a (few) question(s):
1. Is there a place where I can look up what an item is by part # or NSN? I never have any luck googling NSN/#'s and getting anything other than govt. contractor sites. I need somewhere that will actually say MS45904-76 is a 3/8" OD, internal/external tooth washer.
2. Does anyone know the #'s (preferably the MS #) for the 5/16" or 1/2" int/ext washers?
3. Can anyone identify the following MS #'s:
MS45904-60
MS45904-69
MS45904-72
MS45904-73
MS45904-77
MS45904-80
MS45904-84
Much thanks!
194
Norfolk, VA
5310-00-080-9786 Characteristics Data
MRCCriteriaCharacteristic
MATTMATERIALSTEEL COMP 1050 OR STEEL COMP 1551 OR STEEL COMP 1552 OR STEEL COMP 1053 OR STEEL COMP 1055 OR STEEL COMP 1060 OVERALL
MDCLMATERIAL DOCUMENT AND CLASSIFICATION66 FED STD ALL MATERIAL RESPONSES OVERALL
SFTTSURFACE TREATMENTCADMIUM AND CHROMATE OVERALL
STDCSURFACE TREATMENT DOCUMENT AND CLASSIFICATIONQQ-P-416, TY 2, CL 3 FED SPEC SINGLE TREATMENT RESPONSE OVERALL
CQFMHARDNESS RATING40.0 ROCKWELL C MINIMUM AND 50.0 ROCKWELL C MAXIMUM
STYLSTYLE DESIGNATOR106 FLAT EXTERNAL AND INTERNAL TEETH
AAUBHOLE DIAMETER0.195 INCHES MINIMUM AND 0.204 INCHES MAXIMUM
ABKVOUTSIDE DIAMETER0.580 INCHES MINIMUM AND 0.610 INCHES MAXIMUM
ABPXMATERIAL THICKNESS0.028 INCHES MINIMUM AND 0.034 INCHES MAXIMUM
SR-1MANUFACTURERS CODE96906
SR-1DEFINITIVE GOVERNMENT SPEC/STD REFERENCEMS45904-60
5310-00-067-6357 Characteristics Data
MATTMATERIALSTEEL OVERALL
AAUBHOLE DIAMETER0.255 INCHES MINIMUM AND 0.267 INCHES MAXIMUM
ABKVOUTSIDE DIAMETER0.880 INCHES MINIMUM AND 0.900 INCHES MAXIMUM
ABPXMATERIAL THICKNESS0.032 INCHES MINIMUM AND 0.040 INCHES MAXIMUM
ZZZTNONDEFINITIVE SPEC/STD DATA3 TYPE AND 1 STYLE OR 2 STYLE AND 1 COMPOSITION
SR-1MANUFACTURERS CODE81348
SR-1NON-DEFINITIVE GOVERNMENT SPEC/STD REFERENCEFF-W-100
SR-1DEFINITIVE GOVERNMENT SPEC/STD REFERENCEMS45904-69
5310-00-889-2527 Characteristics Data
AAUBHOLE DIAMETER0.320 INCHES MINIMUM AND 0.332 INCHES MAXIMUM
ABKVOUTSIDE DIAMETER0.865 INCHES MINIMUM AND 0.900 INCHES MAXIMUM
SR-1DEFINITIVE GOVERNMENT SPEC/STD REFERENCEMS45904-72
5310-00-728-2044 Characteristics Data
ABKVOUTSIDE DIAMETER0.965 INCHES MINIMUM AND 0.985 INCHES MAXIMUM
ABPXMATERIAL THICKNESS0.037 INCHES MINIMUM AND 0.045 INCHES MAXIMUM
SR-1DEFINITIVE GOVERNMENT SPEC/STD REFERENCEMS45904-73
5310-00-953-8628 Characteristics Data
AAUBHOLE DIAMETER0.383 INCHES MINIMUM AND 0.398 INCHES MAXIMUM
ABKVOUTSIDE DIAMETER1.045 INCHES MINIMUM AND 1.070 INCHES MAXIMUM
ABPXMATERIAL THICKNESS0.042 INCHES MINIMUM AND 0.050 INCHES MAXIMUM
SR-1DEFINITIVE GOVERNMENT SPEC/STD REFERENCEMS45904-77
5310-00-080-9785 Characteristics Data
MATTMATERIALSTEEL COMP 1050 OR STEEL COMP 1566 OVERALL
SFTTSURFACE TREATMENTCADMIUM OR CHROMATE OVERALL
AAUBHOLE DIAMETER0.448 INCHES MINIMUM AND 0.464 INCHES MAXIMUM
SR-1DEFINITIVE GOVERNMENT SPEC/STD REFERENCEMS45904-80
5310-00-935-8984 Characteristics Data
MATTMATERIALSTEEL COMP 1050 OR STEEL COMP 1551 OR STEEL COMP 1552 OR STEEL COMP 1053 OR STEEL COMP 1055 OR STEEL COMP 1059 OR STEEL COMP 1060 OR STEEL COMP 1561 OR STEEL COMP 1064 OR STEEL COMP 1065 OVERALL
AAUBHOLE DIAMETER0.512 INCHES MINIMUM AND 0.531 INCHES MAXIMUM
ABKVOUTSIDE DIAMETER1.220 INCHES MINIMUM AND 1.260 INCHES MAXIMUM
ABPXMATERIAL THICKNESS0.047 INCHES MINIMUM AND 0.055 INCHES MAXIMUM
SR-1NON-DEFINITIVE GOVERNMENT SPEC/STD REFERENCEFFW100
SR-1DEFINITIVE GOVERNMENT SPEC/STD REFERENCEMS45904-84
1,168
"MS" = Mil Spec
Simply Google the MS number.
Tow4
622
Orlando, FL
Will these work?
Check McMaster-carr PN 95795A030. That get you to the right page to look at the sizes available. These are inside and outside tooth star washers with a minimum hardness of C40.
1,123
Here's an awesome sauce chart of everything you need from 3/16" to 1/2"
Man, that is awesome! Mucho thanks!
Where did you find that? Do you have access to the system or is that buried in a TM somewhere?
"MS" = Mil Spec
I did-see "I never have any luck googling NSN/#'s and getting anything other than govt. contractor sites."
Whenever I try to identify either MS or NSN #'s, all I can find are contractor sites that show they can order them and occassionally what they cost and that's it-there is never a description of the item.
I research car parts for a living-and I've done it for a while. I am not bad at it. In fact, I am pretty good. But I've had no luck finding a way to identify a lot of this stuff. If I am missing something obvious, show me and I'll take my ribbing.
For instance, the 1/2" one:http://bit.ly/11saw6A
Of ALL the first page results, only wbparts.com and parttarget.com had any specs (and I must have missed them before, or I searched a different # that they didn't have).
There has to be some kind of central place to research this stuff.
Will these work?
Other than those being zinc plated and me being after cadmium plated, they would work. I am being real picky about what I want, since it's going on this: IMAG1846800x600.jpgIMAG1940800x600.jpg
Due to moving chicane's help, here are the remainder of the part #'s for those interested. All sizes represent inner diameter:
MS45904-60 3/16"
MS45904-69 1/4"
MS45904-72 5/16"
MS45904-73 5/16" ID with a larger OD
MS45904-77 3/8"
MS45904-80 7/16"
MS45904-84 1/2"
Much thanks to everyone for their help!
C
