Start/Stop handle, what do you do?
saddamsnightmare
82
Abilene, Texas
:-DFebrary 28th, 2009.
My chock lives under the passenger bench seat in the cab.... The parking brake might hold the truck, the transmission won't hold the truck if pushed hard enough, and I gotta make up a locking engine stop handle block, what with everything else on that truck, the big safety items get attended to first, the little ones are less likely to kill you.......
Other then being primitive, the deuce has many good points and some bad ones (like that little pain in the @#$%^&*()!# driveshaft between the transmission and the transfer case, a real pain to check, but one you don't want to get loose at speed!:twisted:
Cheers,
Kyle F. McGrogan
1971 Kaiser Jeep "Saddam's Nightmare" Desert Storm and Vietnam Veteran Deuce
1968 Johnson Corp M105A2 trailer
1967 Hercules MEP023A gas Gen Set APU
1963 Swiss Army Cargo Unimog S.404.114
kendelrio
9,596
Alexandria, La
I keep mine pulled out..... One more thing for the uninformed to figure out if they are trying to start said deuce without permission....:twisted:
BTW, Jinx, You are forgetting K.A.R.R.
JDToumanian
17
Phelan, CA
in the tool box......:roll::grin:
I keep mine in the tool box, but Dave Walker's Air Force deuce which I am working on has "DO NOT PUT CHOCKS IN HERE" stenciled on the tool box door. I thought, uh, why not? ...That's exactly where I put my chocks! Why would the air force not want chocks in the tool box?
As for the stop cable, mine has no ratchet teeth on it and is spring loaded so that when you let it go it pulls itself back in. I leave both trans and transfer in neutral....
Jon
Westech
CPL
6,104
212
cow farts, Wisconsin
I'm anal about it being out. If the ratchet pawl on a cable stops working, I'll change the cable. These things bump start so easily that I get paranoid about an accident happening.
I remember hearing about a M109 that was push started by a huge wind storm and entered a building and made a new door. Kenny is correct the Multi fuel when working well will start by just looking at it too hard. I know my old deuce would be running before I could even just try to bump the starter to move a pulley to change the air pump belts. I finally had to just VERY slowly turn it with a wrench.
bigmike
363
Dixon CA.
I leave mine out. I leave her in gear as well. I installed a Cat switch under the dash so there is no starting without getting under the hood and doing a bit of work.
1,193
Battery disconnect.
331
Claymont, DE
I've got a screw out disconnect on the negative terminal on mine, I leave the fuel cutoff pushed in because I really don't need it gumming up on me in a cold snap, but, I also never leave the trans or Xcase in gear, hand brake always on and a cinder block between the duals.
