started painting my M818 today started with the engine
jrobinson5093
jakin georgia
I have seen a few red cummins and I wanted to do something different. I plan to paint the rocker covers black. I wanted something that would catch your eye through the inner fenders also. And yes it was duplicolor engine paint, it says good to 500. I figure that the exhaust manifold will burn off, but I plan to build a header of sorts later any way.
Castle Bravo
Hundredaire Socialite
215
Arizona
Maybe you can tell people its an ISX.
I will say this, it should make spotting leaks easy.
jrobinson5093
jakin georgia
I will use a da sander with some some 320 sand paper to take the paint off and to get every thing smooth. Then prime and block everything smooth and straight. I will either do the truck in black or tan and black.
Ray70
5,853
West greenwich/RI
No need to start with 320 to strip it down, it will take way too long, use way too much sandpaper and you'll go through a ton of Beer in the process.
Start coarser and work your way down, it will go much quicker. On cars I start with 36 on an 8" rotary sander ( only strip 75% of the paint, avoid sparks from grinding into the metal ) , then 80 on the DA to remove remaining paint, then 150-180 DA and prime. If the truck is severely sun bleached you can probably start off with 80 grit and go up from there. See what works fastest without damaging the metal. Once stripped immediately apply either 1 coat of etching primer or epoxy primer before applying your 2K primer surface. NEVER use lacquer primer! Its garbage and will blow right off the truck if you apply it directly to smooth steel. If you don't plan to strip it down to metal I would start with 150 grit, then 220 then prime.
