- 4,640
- 32
- 38
- Cambridge, Ohio
Well, like the title says, I pulled the trailer up out of the yard today and started going over it to start it up. I had to remove the broken tank drain valve, just plugged it lightly for now so I can still drain it when the air pressure bleeds off some. Put a few gallons of gas in the tank. Looks like the engine has a new oil filter on it. I checked the oil and it was full and clean, took the glass bowl off of the fuel line before the carb, I assume that's a water separator and filled it with gas. Hooked up the jumper cables to the deuce batteries. Then I choked it and cranked for about 20 seconds. I didn't want to over heat the starter. I left it cool a minute and cranked again, this time fuel was finally getting to the engine and it seemed like it wanted to start, but didn't. After letting the starter cool for another minute, I set the choke to half way and cranked again....she fired up that time. Oil pressure came up pretty quick, probably because of all of the cranking. Left her warm up a few seconds and removed the choke and she purred like a lion (too loud for a kitten).
Now I have to reset and probably replace the governor for the air, the first time the engine didn't throttle back until it was at about 200 psi. I turned on the air to the pumps and they took right off, of course they did because the tanks are empty. That drained the air enough to kick the engine back up, but instead of coming up at about 150 psi like spec, it didn't come on till about 100 psi. I don't know what happened that first time, because it cycles at about 100 and 120 to 125 psi. Not 150 and 175 like spec. I'll post some pictures a little later, I'm kind of swamped because we're leaving to go out of town tomorrow. I'll work on it more when I get back. I'll try to get the pics up later this evening.
WHAT A BEAST !!!!
WHAT A BEAST !!!!
