motormayhem
- 6
- 18
- Tucson, AZ
Replaced my flex plate about 2 years ago when the tranny was done as there was a few teeth that were messed up from having the starter relay stick. Since then it has always started with no grinding or problems of any kind. Today I went to start it up as usual and it just spun like the starter wasn't engaging the flexplate. Cranked it a 2nd time and it fired right up as usual. Started and stopped it about 20 times and it did it about 3 times. I can hold the key in the crank position and the starter just whirrs. If I stop and wait a second or two it will fire up on the next try.
So I dropped the inspection cover and none of the teeth are worn down other than a few minor spots on the sides of a few teeth in areas where the starter engages frequently.
My question is I need the truck 100% starting saturday for some long trips into some remote areas. What is most likely the cause of such an issue? Bendix not throwing the starter out to engage the flexplate? Is there a good way to test that other than watch it when it does it (hard to replicate)? Finally, is there a method to installing the starter to get good mesh? I did have it part way out to put the motor mount bolt in about a week ago, but I only removed the rear bracket, and the starter bolts to lower it and then put it all back together without ever moving it more than 3in. Also everything was tight when I checked it.
Thanks!
Thanks!
