starter from rare electrical pros and cons
dstang97
30
Clover, SC
Con- Made by 10 year olds in China.
Con- Most people that buy them buy 2, 3 or 4 before getting their OEM one rebuilt
Pro- Price
ralbelt
9
West Warwick, R.I.
Ditto on rebuilding the oem starter. The oil leak may be from the valve cover, you will have to get in there and poke around. The screeching is probably the starter gear grinding against the flexplate. You will have to inspect all the teeth on the flexplate, if any are damaged you will have to replace it or risk damaging the new starter again.
ODdave
lansing michigan
dont forget the brace on the back of the starter, make shure its there and check it for cracks. Just last week had to extract a broken starter bolt in a civi 6.5 (failed due to a cracked brace) customer tryed to remove the bolt and broke the "easy out" off in it .......fun fun.
ralbelt
9
West Warwick, R.I.
oem, original equipment manufactuer, have yours rebuilt. A good shop should be able to rebuild yours for about $100.00.
Be sure that you have the support bracket on the back of the starter and replace the mounting bolts with new oem bolts. All the part #s are available on this site.
