starter help
Westech
CPL
6,104
207
cow farts, Wisconsin
Well you have a bad starter or power coming down to the relay. check it out before you go install a 12v starter. If you look at the wkki you will find out how to do the 12v starter.
Ken_86gt
Williamsburg VA
If there is power on the on the wire that you connect to the starter solenoid - then of course the starter will run. That is how starters work. Are you asking how to convert your truck to a 12V starter? The wire that you attach to the starter solenoid should only have voltage when the key is turned to the start position.
CUCV85
central/ny
Conversion Conversion of M1008 and M1009 Electric Systems to 12 Volt (PDF)
Search 24 volt to 12 volt convertion CUCV using Yahoo search engine.
:arrow:Conversion of M1008 and M1009
PDF file will appear 10 pages with great pictures.
ken
24
Houston Texas
There is a relay under the dash near where the radio would be. It's small. About a inch by two inches. It has failed in the closed position. Causing the starter to turn. You can buy a A/C fan blower motor relay for a 1982 chevy truck from the auto parts store. It's the same part. Unplug the old one and plug in the new one. You should be good to go.
