Starter install question
BigDuck
arkansas
I just had my starter rebuilt and when I went to but it back on the bracket on the back doesn't line up now????? would I be ok to drill another hole in the bracket so it'll fit or is the a bad idea,and another thing the spacer that goes between the starter and the block it wont fit either?I put one bolt thru one hole and just moved it as close to the other bolt as possible so it would at least do its job and space:x, i'm i screwed ??
BigDuck
arkansas
its the right one , the hole in the bracket is only off by a 1/4", the starter works fine but that bracket is there for a reason so i dont like the idea of not haveing on there.
Keith_J
1,317
Schertz TX
The original 27MT starter is direct drive and NEEDS the back bracket, otherwise the aluminum nose piece where the bolts go through will break.
The newer gear drive starter (motor axis is off the pinion axis) is much lighter. And because the stud where the bracket attaches is slightly off, the bracket won't fit. You have to measure and drill.
kenny
San Antonio Texas
It should line up if it is the one that came out of your truck.
maby try to put the bracket on the starter first very loosely then bolt the the other end up.
Mudstone
Norman OK
i don't understand how the same starter can no longer fit? that doesn't seem to make any sense to me is this possible that it's the same starter?
BigDuck
arkansas
when I took it off the back cap and steel sleeve was loose, the back cap is held on by two 5/16" bolts with one being used to hold this bracket aswell, well it was bent when i took it off, now its repaired and the new bolts is straight and wont let the bracket line up.
