catskillpond
- 0
- 16
- wurtsboro ny
I wanted to replace the oil line from block to gauge fitting always leaked at the bulkhead fitting on firewall. On the other side t fitting with starter lockout switch never knew it was there how does this function is wire 93 go to ground in the protective control box and works on not enough oil pressure I am understanding this is a ground wire. Thanks for all replies Scott
