Starter NHC250
CMSGT
Utah
Wheres the best place to pick up a starter for an M809 5 Ton with a NHC250 Cummins? I thought my betteries were bad but it looks like its the starter, it barely turns over. Any info is appreciated.
cbvet
20
Northwest (Knox) Indiana
Check for a good ground. In my experience, most vehicular electrical problems are caused by a poor ground.
If you do need a starter, is there a rebuilder in your area?
An auto parts store should be able to get it done for you or know where to send you.
Or maybe someone on here will have one, but shipping would be pricey.
I would try rebuilding it or having it done first.
dk8019
52
Lovettsville, VA
I had one on epay last week, but it's off to a new home now. I'll echo what cbvet says, the starters are hard to kill, check all the electrical first, the frame to engine ground etc. Any extra resistance means not enough speed to get her going. It seems the Cummins is somewhat sensitive in that regard.
CMSGT
Utah
It was tutrning OK until my batteries went dead, I replaced the batteries and then it would hardly crank. I think I smoked it by trying to keep cranking for a few more seconds because it would almost start. I put in the new batteries, tried turning it over and as soon as I did my battery voltage dropped to 21 VDC with the starter barely turning the engine over. I even hooked up my 24volt engine starter and had the same results. I will see if I can get the starter checked tomorrow but I think thats the culprit.
area52
San Bernardino CA
The guy on ebay with those used to be on here, he is a good guy and I would recommend him.
But I second the getting yours rebuilt, go find an alternator shop, they should be able to do it.
papercu
31
Baxley, Ga.
The 2920-00-304-3493 comes back as for the M939, M939A1, M939A2 but the mounting flange is adjustable to 12 positions, so it should fit a lot of engines. Wayne
CMSGT
Utah
I installed a used starter and repalced my batteries and the truck turned over faster than I have ever heard her! Thank you all for he help.
Ferroequinologist
Resident railroad expert
724
Liberty Hill, SC
I would take that starter that you took out and get it checked, it could be something simple and then you would have a spare, or rebuild it and sell it, getting your money back for the used one you just put in.
CMSGT
Utah
It was toast, I tried and tried to get it to start and I just cranked a little to long. It is amazing the difference in cranking with new batteries and a new starter!
