Starter Question?
deuce_m35a2
Levittown, PA
I need to find out if my starter is any good before i install it. I won an LDT4651d at gl, and needed the starter off it. I am still in process of getting this running, and havent purchased new batteries for it yet. Is there a way I can hook up one 12v battery to it and will it spin enough for me to know its good. If this is possible, which terminals on the starter can I connect the battery to?? any help would be appreciated.
Christian
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
No reason not to try 12v. If it spins at all, its probably good. I wouldn't do it for long as it will try to pull a sh1t load of amps. :)
m-35tom
221
eldersburg maryland
connect the battery to the big term on the selenoid that still has the motor wire on it. no load probably won't pull more than 100 amps
