Starter Relay help
18operator
1,861
Seville, Ohio
I had the same problem with my starter relay. I removed it and took it apart. I found the contacts were dirty, so I cleaned them and relocated the relay away from the damaging heat. And the relay still works fine.
97
39
South bend,Indiana
Recently tried to start my 66 m35a2 and got nothing after pushing the button, I ordered a new push button and still nothing happened. Tested everything and found that no power was leaving the relay. Read some of the posts about taking it apart and cleaning it and read others about not even needing it. Is there a way to skip the relay and direct wire the push button to the starter?
