billybatts299
- 0
- 0
- Bel Air, Md
I got the Run On before I was able to do the Doghead mod. I tried to disconnect the battery as quickly as possible but I am afraid I killed the starter. Luckily the guy I bought the truck from had a new starter, along with a bunch of other new parts from the unit that sold it to him (he retired from that unit).
I replaced the starter and completed the Doghead mod. I double checked the Doghead relay mod connections multiple times and I am confident they are hooked up correctly. However if I connect the battery I get power to the gauges even without the key even in the ignition. If I turn to start the new starter relay makes a click noise but nothing happens.
What are the other components that get damaged when you have a Starter Run On? Could my wires under the dash melted together causing this constant power issue? How can I verify this new starter is not 12V?
Thank you for any assistance!
