- 2,186
- 87
- 48
- Zimmerman MN
Started my 936A2 up, moved it from the yard to in front of my garage to fix a fuel line on the right tank that broke off, replace a pin that holds in the heavy lift jacks and switch CTIS ecu units to try troubleshooting my CTIS doing nothing. Put the CTIS ECU from my tractor in and it actually cycled some air(put the ECU unit from the wrecker in my tractor and it worked fine).
Now I'm getting nothing but a click from the protective box when I try to start the truck. Gauges all work when the battery switch is turned on so I presume the protective box is okay, Solenoid/ Starter all of a sudden? Don't even know where to begin here, how can I jump the solenoid to see if it's bad? Which terminals do I want to jump?
Thanks, Bob
PS. I'm getting over 25 volts at the starter and solenoid connections
Thanks, Bob
