starter?
blackhueys
-9
mn
ok need some help here. i fried my wiring harness the other day from the stupid relay under the dash getting stuck on! fixed the wires but now when ever I go to reconnect the battery the starter engages and turns the engine over regradless if the ignition key is in or not. what else could i have missed not fixed! What causes this to run all on its own?
1,176
Did you replace the relay with a new AC-40 relay?
Did you replace the starter?
Did you repalce or repair the wiring, exactly as it was(needs to be)?
Need more info.
blackhueys
-9
mn
yes up graded the relay to your mod. Starter is fine had to replace the solenoid on it though. good voltage.
1,176
I would start by testing all 4 connection on the new under dash relay. Confirm they are correct.
Then I would confirm the wire connections on the starter solenoid.
I have heard of people accidentally pinching the purple(iirc) wire at the starter solenoid, to the starter battery cable.
blackhueys
-9
mn
ok well I will go look and see what I can. just weird it only does it when the battery gets reconnected. thanks
ralbelt
9
West Warwick, R.I.
After reading this I am so glad that I did the" DH starter relay modification" before I had a problem. I really think that anyone with a CUCV that does not do this 1/2 hour upgrade is waiting for a major failure.
