Starting below 0 degrees?
Mike_Pop
NJ
I have a diesel fired water heater that I've had kicking around in my garage for a few years. I wonder if that could be used to run coolant through?
mangus580
282
Western NY
Military one? dont see why not either way actually....
Mike_Pop
NJ
Mike,
I'll have to snap some pics when I get home next week. The heater is military, German made, for making hot water. I thought it would be great in a camper. But then again, it would be awesome as a coolant heater. My concern is are there any seals that will corrode? And, once I run coolant through it, I could never use it for potable water.
Jetnoise400
Sparks, NV
Armada said:
That's it Sean. Man, that's clean too! You have to put in smaller batteries (dimensionally), to be able to get the pass side heater and battery boxes installed, correct?
Yup, that's correct Armada. The kit includes 2 insulated battery boxes that are plumbed (air ducts) to the passenger side heater. The batts are much smaller than the 6TLs. Also, that heater is ducted down to the bottom of the oil pan on the engine and transmission. Both have an air chamber attached to the bottom of the pan that allows the hot air to keep things warm.
Still pretty clean under there for 11k miles... thanks for the compliment. My heater kit is also for sale, and like Armada's, mine comes with an M1009 attached also. :lol:
superburban
SL,UT
Do you want to part with it? That would be just the ticket for my portable biodiesel processor project!
Oh. Is it in NV or NJ?
