misterbill64
- 2
- 8
- Buckhannon WV
Well after almost 2 years I finally have enough parts to start. so far its pretty easy removed bed, torched of all the rivets and used the tractor to pull axles out. I removed everything from the rear frame so I can blast it then paint. Planning on an artic camo paint job,(thats what convinced me to buy it in the first place). Drilled all the spring bracket holes and temp installed springs. then cut the rear off the bed, I kind of jump all around with the project but it will get there. Here are some pictures, more to follow!
