Starting new repower/conversion project w/M56 R2 Crash & Rescue Truck
viking1
Az
Thank you, Sir. Yes, bed is in not bad shape (considering what the poor truck has been through). The aluminum in the rear of the quarters has some bends and rips from pushing it with the machine to move it around over the years, but I'll straighten them up. I will be removing the aluminum bed floor to build the dump mechanism once up and running, and will probably just have an "inner bed" that dumps. Would like to convert the rear wheels to duallys, but dont know if that's possible? The winch is coming off this morning; no PTO shaft anymore, so best I send it off to someone who can use it..... :)
Nice progress!!
I see there is more bed left than I originally thought. I (also) will use some diamond plate on the roof (replacing a soft top 923), but I like being able to weld the steel as opposed to aluminum. ...And able to dance on it too (work up high), so will have a bit more support.
Please keep pictures coming. BTW, my 925 winch cable wanted to do exactly what your second photo shows and it was a real one man fight to get it back on properly.
viking1
Az
The hood and Braden LU-4 were removed today. Also sanded and prepped the hood, and would have painted it (were it not in the 30's). Maybe tomorrow.... :)
viking1
Az
I took a couple of months off to fully restore a 1954 Ford Golden Jubilee tractor (but that's a story for another forum). I spent the last couple of weeks building a gantry hoist & trolly around the truck bay, installing new gauges in the dash, and building/installing new diamond plate door panels. I should begin shoehorning the engine in this week.... :)
combat32
106
Booneville AR.
Glad to see she is gonna live again, I agree it was too far gone to restore to original. I for one am glad to see some of these old trucks back on the road serving a useful purpose, better than goin to the scrapper.
viking1
Az
viking1
Az
Its going to be a tight squeeeeeezzzeee!! Looks like the motor mounts need scooting back about 6", and the exhaust manifolds will have to come off....
Sidi
Bloomington, IL
Thanks for hanging on to the R-2. I'm doing some research on the history of the trucks. Does your cab still have the Oneida tag on the lower end of the battery box, near the passenger door floor sill? If so, could you supply the serial number and manufacture date? Or any dates from the dash tags. Also, do you happen to know what Air Force base the truck served? Thanks!
viking1
Az
Sidi, I hadnt had a chance to do work on the truck due to other projects until this weekend; will get that info and post it in the next couple of days....
viking1
Az
I finally got the time/impetus to get the 440 Magnum engine/trans shoehorned into the M56. It actually looks like it belongs there, now that the mounts are welded up and the engine set in. My BMW mechanic friends ("the Beemer boys") are mechanical geniuses, and together we shoehorned that baby into the bay. The fenders (outer AND inner) fit well, and I'm very pleased with the assembled look. After the engine swap is completed, I'll start on adding the dump bed. Will post some more pictures soon..... :)
viking1
Az
viking1
Az
The newly-installed 440 runs like a banshee. The Ford Taurus fan (4600 CFM!!) install keeps it running super-cool. We haven't seen a temp above 130-140 yet.
The exhaust/mufflers are from a 2006 Ford Mustang 5.0 H.O.. Ultra-quiet, super-clean install, and just great tone. Eventually I will run them into twin stacks just behind the doors.....
We also retro-fitted a brake master cylinder from a 1980 C-30 Chevy truck to give us two-stage brakes (important in a vehicle of this size :) ). The info was easily found on uglytruckling.com, and worked like a charm.... :)
One issue left to be tackled is that the 727 torqueflight wouldnt go into any gear. Fluid is new, so we are wondering if its cooked? If so, a rebuild kit is on the near horizon....
:driver:
