starting with wd-40
Hasdrubal
Vancouver BC
Someone suggested this method to bleed air out of injectors,is this safe?..I don't want to blow a head off.Do you still glow the plugs?..how much do you spray in?..Would I still need to crack a few injectors?..it's my understanding that they can't pass air.
mangus580
283
Western NY
Pure Silicone spray misted in the intake will work just fine. If you look through the CUCV section, i have posted a couple of times how I have bled my system. You shouldnt have to crack the injectors..
steelsoldiers
4,089
Charleston, WV
The old WD-40 would work nicely for that, but with a the new clean air regs out there, they took all the good propellant out of it, it was butane or propane before. Now it ain't nearly as combustible. :cry:
