Steel Soldiers for Dummy needed
Lugnuts
266
Myakka City, FL
I sure could use some educating on the use of the website. I have asked questions, got tremendous answers, and just when I thought I was getting the hang of how to use this website I discovered I was so wrong. I need to replace a driver side door glass on a M1083 and I thought for sure getting the information would be easy ( and maybe it is and I just don't know how to retrieve it) So I hit the particular classification and started going through the "threads" and by the time I hit the 60th page and only half finished I lost my composure and decided to write. IS THERE A SEARCH ENGINE MAYBE I'M MISSING or is it going thread by thread before I write and then someone points out where it is? My powers of observation are leaving me and I sure could use help once again. Thank you/ Lugnuts
hndrsonj
Senior Chief/Moderator
359
Cheyenne, WY
The search is in the upper right (looks like a magnifying glass). I doubt you will find a thread on how to change a window. I'd look in the TM for the procedure to change it.
Lugnuts
266
Myakka City, FL
I did and that just deals with flat glass of the windshield and cab flat windows. Thanks for the search tip/ Lugnuts
NDT
7,505
Camp Wood/LC, TX
To the best of my knowledge, nobody has written a thread on replacing the door window glass, which is why you can’t find it. The TM may discuss it, but if you remove the inner door panel, you will see how the window tracks unbolt, allowing the glass to be removed.
Lugnuts
266
Myakka City, FL
Removal is not like you expect. I just finished the job and I guess I'll write it up. Thank you for you response
fasttruck
638
Mesa, AZ
The procedure should be detailed in the organizational maintenance manual applicable to that particular vehicle. The TM numbers are typically listed on a data plate in the cab. Besides the glass you may need to replace the clips that attach the glass and track to the window lift itself. The TM will explain this.
The TMs are available on line or in the Technical Manual forum on this site.
Lugnuts
266
Myakka City, FL
Appreciate the reply. I have the Manual and it listed the winshield and flat glass repair but did not list the window glass replacement. So I went ahead and figured it out. Thanks for the response
fasttruck
638
Mesa, AZ
The organizational maintenance manual for the 809 series trucks contains detail instructions on replacing the door glass. I cannot imagine how they would omit it from the FTMV unless the task is considered direct support echelon level work
Lugnuts
266
Myakka City, FL
Thank you. I did look that up and you are absolutely correct about the instructions. Unfortunately it is a different style door on the LMTV than the 809 Series and the instructions just weren't there. It was for the flat glass including the windshield but not the door glass. There again I most certainly could have missed it somewhere. Figured it out and wrote a little something about it. Thanks again
fasttruck
638
Mesa, AZ
Never worked with LMTVs and FMTVs in service or read the TMs. If the window info is not in the organizational maintenance manual (-20) the only thing I can figure is the window work was assigned to direct support (-30) level shop work.
Lugnuts
266
Myakka City, FL
I am not familiar with the Tech Manual Protocol and Categories of arrangement. If you have the time could you point me in the direction or explain the different categories. If not I understand. the -20 and -30 doesn't mean anything to me. Thank you
wheelspinner
1,539
North Carolina - FINALLY !
-10 is operators manual, -20 is the level of maintenance permitted at the unit level, -30 is the higher level maintenance only permitted at depot level (or whatever they call it). You may have to look in several different manuals until you find the particular item. Another good manual is the -P which is the parts manual and has exploded views of every single assembly.
Lugnuts
266
Myakka City, FL
I really appreciate that information. I am going to look at the Manual Numbers and see how that reads out. If I have any questions and I'm sure I will may I come back to this thread and bother you more? Lugnuts
fasttruck
638
Mesa, AZ
Post 12 has the straight skinny for those not in the know. The Army has a manual for everything. Vehicles come under the aegis of the Army Maintenance Management System (TAMMS) which dictates 5 echelons ranging from operator (-10 manual), organizational or company level (-20),l Direct Support, (-30),
General Support (-40) and Depot (-50). From the 2nd echelon up there is a companion parts book that lists the parts that each level is authorized to use. Another publication lists which tasks each echelon is responsible to do. Depot does not replace light bulbs and organizational do not rebuild engines. Most private owners should have a -10, -20, -20P and a lubrication order particular to their vehicle. The TM numbers usually appear on a data plate in the cab. This system came to be between the Korean and Vietnam period. WW2 books are different and the material included in todays -10 and 20 manuals was lumped into one book.
Lugnuts
266
Myakka City, FL
Well Sir I am your man, the one not in the know on this. Good information! One more thing, where do I find Post 12? I truly didn't and don't know how this information is arranged. I am sure it has a beginning and if it is Post 12 please say where I can find that. I'm sure I'm not the only one. Thanks a whole bunch/ Lugnuts
hndrsonj
359
Cheyenne, WY
It is the number of replies. This is post#16. Look at the numbers to the right.
