"IN"IN...
INWe're at it again, another giveaway, this time from Memphis Equipment. Thanks goes out to Doug at Memphis for sponsoring this giveaway. He has graciously provided a $250 in store credit! The rules are much like the last giveaway. Simply reply to this thread with a "IN" and you'll be entered to win in the contest. Only one entry is required. (Multiple replies will not be counted) We'll hold the drawing for this May 15th. A list of all the contestants will be published prior to the drawing as well. Also if you upgrade your membership during this contest, we'll enter you a second time. Also we've extended memberships from 12 months to 14 months during this window. Thank you all for being a part of Steel Soldiers and good luck.
Thanks again to Memphis Equipment
inWe're at it again, another giveaway, this time from Memphis Equipment. Thanks goes out to Doug at Memphis for sponsoring this giveaway. He has graciously provided a $250 in store credit! The rules are much like the last giveaway. Simply reply to this thread with a "IN" and you'll be entered to win in the contest. Only one entry is required. (Multiple replies will not be counted) We'll hold the drawing for this May 15th. A list of all the contestants will be published prior to the drawing as well. Also if you upgrade your membership during this contest, we'll enter you a second time. Also we've extended memberships from 12 months to 14 months during this window. Thank you all for being a part of Steel Soldiers and good luck.
InWe're at it again, another giveaway, this time from Memphis Equipment. Thanks goes out to Doug at Memphis for sponsoring this giveaway. He has graciously provided a $250 in store credit! The rules are much like the last giveaway. Simply reply to this thread with a "IN" and you'll be entered to win in the contest. Only one entry is required. (Multiple replies will not be counted) We'll hold the drawing for this May 15th. A list of all the contestants will be published prior to the drawing as well. Also if you upgrade your membership during this contest, we'll enter you a second time. Also we've extended memberships from 12 months to 14 months during this window. Thank you all for being a part of Steel Soldiers and good luck.
