Migginsbros
- 7,457
- 113
- Berlin-Germany
It´s raining today and we will go out for hunting some gifts for the family. Yes, the shops are open on Sunday. That´s not normal but these day´s it´s allowed.
But before we have to do something MV related. We check the on board stuff we still get with the truck.Wheel chains, chains for recovery, cable pulley,90 feed additional steel cable, blackout set for windows,mirrors, headlamps, etc.. Repaint the wheel lug wrench and the clutch pedal extension you have to use if no air power clutch assistant is available and you´re leg is not strong enough.
The box with the toggle switch is for communication with the troops in the back because they can´t knock at the rear window if something goes wrong.
So they have to give a signal to the driver. The Y-Pipe you install for getting warm air from the Diesel heater to warm up (in about 1.5 hours) the aircooled engine and the batterie compartment if temp is under -10°F (-25°C). Next days we have to repaint the wheel chocks.
Happy holidays,
Migginsbros
Edit: Spelling
Happy holidays,
Migginsbros
Edit: Spelling
