Steel Soldiers MV of the month 2025 - January VOTE HERE!
5,123
1. Weldman
2. Lawdog734
3. Blaines2399
4. muthkw25
5. sigo
6. Dieselfitter
Weldman
Decommissioned
1,788
Miles City, Montana
Story goes I went to an auction in Nebraska 1k miles away in the middle of nowhere held in a corn field to look at the rig before bidding. Went through the usual inspection found that injection pump shut off was sticking and not allowing it to return when ignition is turned on without reaching up there and moving it so it would start.
Welp I put it back as I found it and no one hardly bid on it, went for $9k which included a 2600 gallon water tank on the back I could use and was worth almost the price I paid for the truck.
Bought the truck and drove it 1k miles doing 50 mph all the way home, last 30 miles it blew the air dryer purge valve that I ended up shoving whatever to plug it and bled the lines off so it wouldn't have to purge.
Been a work horse for me since day one getting stuff here that a pick up couldn't do nor a semi. Need to invest in a M920 to convert to a dump truck or try to get lucky and find a M917, need articulating axles up here.
Has been a help to the community here for when they get stuck or the county grader gets stuck in the snow.
What a lot of people don't realize is those windows on the back of that truck are worth $30k plus that I entrusted this 5 ton to carry 35 miles down gravel/mud roads and up 3 miles of ridge to get to my home.
If work is needed done, this truck has been there through thick and thin.
Weldman
Decommissioned
1,788
Miles City, Montana
The story behind the blocks on the back of the rig in my campaign picture is not for traction. There is 6 back there at 3300 lbs at piece @ 19,800 lbs on the back. That truck hauled 73 back here weighing in around 240,900 lbs worth of concrete in a month time frame, pick up 6 drive home from work, off load them and go again. They are to build up a ridge where my house is going overlooking thousands of acres seeing from Montana to Wyoming.
I also use mine to haul water back to my home from a well I personally dug all 1500 gallons at time over rough terrain to the point over 5 mph will cause tank to slide side to side.
