Steerable Trailers?
Mainsail
1,805
Puget Sound, WA
There always seem to be a few dual axel steerable trailers on the auctions but I never see any on the road.
They would probably make good utility trailers for hauling stuff- no tongue issues to deal with. Are they not allowed on the roads? Do they not track well at highway speed?
goldneagle
1,513
Slidell, LA
The wagon style trailers like M989A1 come to mind when you made your comment. They are beasts as far as weight is concerned. They max out the tow capacity of a M35 without any cargo. As far as handling they are fine in forward motion, but a real pain in reverse due to the steer axle. I know someone that has one. He has not used it since he brought it home several years ago.
Some of the wagon type trailers are Air Force issue for low speed runway use and are not rated for highway use.
86m1028
17
Murphy TEXAS
Hey I resemble that remark !
I have an m989A1 it is in great shape but it is now "lawn art".
1,827
Walkerhunter drags his missile command trailer to the GA Rally every year without issues. What is the difference between these and the second trailer of doubles?
rustystud
3,392
Woodinville, Washington
Nothing, their the same thing. You just need the appropriate towing vehicle. Now if your towing two of them behind your regular fifth wheel trailer then they can get squirrely. Oregon still allows triple's and I still have my triple endorsement but I would never tow them again !
Tinstar
2,622
East of Edmond, Oklahoma
The M989A1 tows great with my 5 tons.
Backing it up is totally different!!
I always prided myself as fairly skilled when backing up a trailer.
The M989A1 wins every time.
I cannot back that thing up more than 5 feet before it wins.
Locking the pin wouldn't help me as I'm not in a huge smooth surface lot, so all I would do is just shear the lock pin.
Its great for hauling hay. For me that's about it.
zebedee
conceptualizer at large
898
Central NY
This setup is used extensively in old Europe - years ago it was more common than semi's. Appropriate tow vehicle, generally with it's own load, is a must.
We do our own hay and I am currently up to reversing this type of wagon, behind the baler - 3 steerable pivot points. Next will be two hay wagons - 4 steerable points.
There is an incredible video out there of a trucker reverse-turning around a log combination on a mountainside,with barely enough width to jackknife the trailer and turn the whole lot 180 deg around....
...... found it:- https://www.youtube.com/watch?v=coa4sWcDCXc
Tinstar
2,622
WOW
Now that was very impressive
porkysplace
1,496
mid- michigan
I doubt you will shear a 2 1/2" pin . Michigan specials are used daily off-road and dolly locks rarely break (unless they are worn out and neglected). 160,000 lbs is a legal load here in Michigan.
Tinstar
2,622
So you can lock out the pivot on the m989a1? How does that help backing? Seems like backing like that would result in a bent tongue.
It's only for backing straight back according to the TM.
No turning whatsoever or you will just shear the lockout pin or just bend stuff up.
Its a heavy trailer. 11k empty.
