Steering box leaking
rookie
portcharlotte fl
Today I was having a little fun with humvee off-roading right before I got home heard this wind in noise when turning and braking. Well when I come to look my steering box is leaking from the seal really bad are these rebuildable and also what part number are they if I were to get it at discount auto parts it should be a gm steering box any help would be appreciated thanks rookie
darr3239
Arizona
So far, with my new to me HMMWV, I've found next to nothing at local parts stores.
24 volt items are like hens teeth, and I'm finding just about everything else on a HMMWV is similar. I guess it's what makes it a hobby!
Retiredwarhorses
3,885
Brentwood, Calif
I find that most of what I can find at the auto stores is rebuilt and rather junky....or just plain junk.
another reason I try to stick with NOS. but steering gears can get quite pricey....I went that route once, got a rebuilt gear by Cardone at O'reillys....it looked like a 15yr HS auto shop student rebuilt it.
rookie
portcharlotte fl
Well i found a guy that has nos steering gear for 150.00 he doesnt know if they were rebuilt or new they have a tag on them. So i think im gonna go that route. Also i found a guy in alabama called sax express that rebuilds them for 295.00 complete overhaul
juanprado
2,711
Metairie/La (N'awlins)
I stayed at Holiday Inn express...
I have not worked on a humvee specifically but have worked on GM steering boxes. Typically changing the top o ring / seal gasket is not a bad job. Just 4 bolts.
Check out the tm, don't take just my word but if it is like a 80-90's suburban/pick up not too involved
