Soaper
- 0
- 0
- clarksville tn
So my 86 09 came without and ignition switch. Just an hole in steering column where it would be.
Anyway pulled steering wheel. Horn misc all missing. Turn signal switch wasn't screwed in. No snap ring or spring.
Anyway put an used CUCV ignition switch in. And it was worked right. That gear behind it was turned too far back. So had to pull steering column apart an little bit.
Well the key will work and spring back to run. But I can't move shifter. Or I can move shifter and key won't work. Lol
Does any of this sound familiar to any of you? I have all the stuff to put the steering wheel back together but its staying apart till I figure this out
