Steering column issues.
Soaper
clarksville tn
So my 86 09 came without and ignition switch. Just an hole in steering column where it would be.
Anyway pulled steering wheel. Horn misc all missing. Turn signal switch wasn't screwed in. No snap ring or spring.
Anyway put an used CUCV ignition switch in. And it was worked right. That gear behind it was turned too far back. So had to pull steering column apart an little bit.
Well the key will work and spring back to run. But I can't move shifter. Or I can move shifter and key won't work. Lol
Does any of this sound familiar to any of you? I have all the stuff to put the steering wheel back together but its staying apart till I figure this out
the skull
12
mt victory ohio
Can you adjust the rack and pinion on the switch some more?
If that's possible, I've never had to mess with one. If it did not
cooperate, I would swap it for a tilt column out of another
truck. I might swap mine out later anyway
spectre6000
Broomfield, CO
Could you take some photos of the disassembled steering column? I have a project coming up, and finding photos to figure out what to expect don't seem to exist.
