Steering problems on MB
Miltrans
Denmark
Hi. I'm trying to fix the steering on a late Willys MB. Someone has "opperated" on the steering and not got it right - AT ALL.
It looks as if the housing is from a M38A1 (larger than MB) but I have a sneaky feeling, that the actual steering coloum with the worm gear is from MB. The function is as if the worm and sector shaft dont match.
How do I tell the parts appart? I can see that the MB shaft with worm and sector shaft on MB and M38A1 have different parts numbers, but I am having trouble finding out what is it I actually have.
Hope someone here has info.
Chris
NDT
7,434
Camp Wood/LC, TX
Properly rebuilding a Jeep steering gear requires a special ream to get the sector shaft bearing clearance right. Too much and you get wobble and play. I say this because my suggestion to you is throw your mismatch gear in the recycle pile and get a reman unit from one of the Jeep parts guys.
