steering specs in TM
Suprman
707
Stratford/Connecticut
I asked some of the local reserve guys they said they do it with a tape measure. Front wheels even spacing back and front of the wheels.
319cssb
221
Easley SC
I think I've seen it in the TM somewhere, but can't find anymore. maybe it was in the HMMWV TM's
Thought it was 0 toe, but not sure anymore
wandering neurons
147
Fallon, NV
0 to 1/8" toe-in (0 to slightly pigeon-toed). Army has a tool for the job but I measured from inside of each tire at 23" up from ground, front and rear. I marked the spot on the inside of each tire then measured using an old carpenter's rule, then checked with a regular tape measure.
TM 9-2320-365-20-3, section 13-5
Suprman
707
I got mine close with a tape measure and some string. I would like to find a place to do a real alignment but the tires dont fit on the semi truck alignment machine.
wandering neurons
147
Fallon, NV
Mine had about 3" toe in, to go with improperly shimmed king pins on the axles, and a damaged/worn steering box overstressed by the king pins binding. Now drives like a dream! Thanks Suprman for the steering box!
