Steering Wheel Nut size
quarkz
Supreme Galactic Cleric
74
Kennewick, WA
Would anyone be able to cross NSN 5310-00-995-1833?
It is the steering wheel nut on the m35a2.
The part is called for in the TMs but the only desc. is hexagonal nut.
But not the size it looks like a fine thread 7/8-14.
I will try one after I pick it up from True Value.
I found out last night that mine was something larger that was welded into place.
Thanx for any help.
Tony
emmado22
168
Mid Hudson Valley NY
User ID: castle nut
Characteristics Data Response for NSN 5310-00-070-1902
Item Name: NUT,PLAIN,SLOTTED,HEXAGON
MRC Requirement Statement Clear Text Reply
NAME ITEM NAME NUT,PLAIN,SLOTTED,HEXAGON
AAJD THREAD CLASS 2B
AAJF THREAD DIRECTION RIGHT-HAND
ACTA NUT STYLE A17 SLOTTED, HEXAGON
ADEA NUT HEIGHT 0.831 INCHES MINIMUM AND
0.887 INCHES MAXIMUM
ASDB WIDTH ACROSS FLATS 1.450 INCHES MINIMUM AND
1.500 INCHES MAXIMUM
AZKQ TEMP RATING NOT RATED
BZRR THREAD SERIES UNF
CMLP THREAD QUANTITY PER INCH 12
CQFM HARDNESS RATING 69.0 ROCKWELL B MINIMUM AND
32.0 ROCKWELL C MAXIMUM
CQJX NOMINAL THREAD SIZE 1.000 INCHES
CRTM BEARING SURFACE TYPE CHAMFERED OR WASHER FACED
MATT MATERIAL STEEL OVERALL
SFTT SURFACE TREATMENT CADMIUM OVERALL AND CHROMATE
STDC SURFACE TREATMENT DOCUMENT QQ-P-416,TY 2,CL 3 FED SPEC
AND CLASSIFICATION SINGLE TREATMENT RESPONSE
OVERALL
ZZZT NONDEFINITIVE SPEC/STD DATA 4 TYPE AND 16 STYLE AND B
GRADE
acetomatoco
9
Nut, Steering Wheel, 5167785 Ordnance #, Studebaker 914537 and historically G509 (truck 4 ton Diamond T of WWII) and more modern 5310-00-995-1833 Ord 7748769 from the 20P 209 series of 1976...
quarkz
74
Kennewick, WA
Thanx for the offer little bob,
I found a 7/8 -14 fine thread castle nut with nylon insert at true value and it threaded onto the shaft just fine.
I will try it for a while and check to see if it comes loose. The locking nylon is a nice touch.
Now I just have to find the right smaller steering wheel to fit. THe 5 ton I tried didn't.
Any idea where to find the NSN # on a 5 ton steering wheel?
I wan't able to find a number on the one O have to cross with the TMs.
Tony
hndrsonj
Senior Chief/Moderator
378
Cheyenne, WY
If I remember correctly, I checked mine with a thread gage and it was like a 7/8 by 20 or 24??? I really believe 14 is way wrong. The center shafts are very easy to cross thread and are soft so installing the nut you may not know it's cross-threaded. Not 100% but would be very curious to have someone check a nut with a gage. I am thinking it's a -20.
