asgtoolman
- 3
- 0
- Florence SC
ok I think I made a mistake the other day, sitting in a parade waiting for it to start, I pulled the rubber cap off of the stering wheel and pulled the stainless steel top piece out, Had no clue what was gonna be there, I was just messing around seeing what it was, well amost 5 ft of rod came out and it wouldn't go back in, it keeps getting stuck somewhere down the tube,
simple question, what is this is how do I fix it, cut it off and just put it in place? or is it more importantant then I think??
thanks.
pictures can be added just ask...
I would laugh at this thread, but it hits WAY too close to home. At least I was not sitting in a parade, but when rebuilding my M-38 I too pulled the horn rod out while cleaning/ rebuilding everything and could not figure out why it would not slide back down as easily as it came out [which was VERY easy] Finally pulled out the TM after hours of fooling around with every imaginable way to push it back in and ended up putting it back thru the bottom. It is impossible to imagine that it can't be done from the top but I sure could not make it work.
