Sticky Deuce Brakes
jeepin
11
Vermont
Before I start tearing wheels and brake drums off, anybody have any ideas for my deuce which has a brake(s) on the rear that drag once in a while in reverse?
Its not the hydro boost locking up because the truck rolls forward when this happens. It is also not all the brakes it feels like only one or two. Parking brake works normally and releases fine.
What happens is hot or cold sometimes when I put it in reverse the brakes grab for a second and then let go, only when backing up.
Brakes are not dragging driving down the road, it seems to be only after a stop and change to reverse.
I am thinking a broken brake return spring, does that sound like a place to start?
Any easy way to figure out which back brake it is?
If you think its in the manual just give me the manual and page, lectures about looking in manual not needed because I did and I didn't see anything about this particular problem. Thanks.
cleb
Huntsville, AL
I believe this sounds like a parking brake issue. I've heard of this issue before with the same symptoms ( sticking in reverse). I'm sure someone who has had experience with the parking brake issue will chime in. I think it has to do with the springs. I would run that to ground before I starting tearing into the service brakes.
glcaines
2,412
Hiawassee, Georgia
I agree - it is very likely the parking brake that is causing the problem. This phenomenon is not that uncommon, and is relatively easy to diagnose and repair.
