Sticky window zippers? Solution..
ida34
36
Dexter, MI
When I was in we used a soap bar but this would look better. Do you get it locally? If so, where?
Chuck
kawkev
Picayune, Ms
Candle wax works good. Bees wax works better. Rub a little onto zipper teeth, then run the zipper up and down a couple of times and clean off any excess wax.
m1010plowboy
2,977
Edmonton, Canada
....and once you get them lubed.... a little squeeze with some needle nose pliers or a spread with a tiny screw driver will get the spacing on the blunt end of the slider re-set for a smooth pull. They tend to widen out and the proper spacing improves mileage.
http://www.toolpak.com/html/INFOZipperAdjustment.html
They are suggesting "Food Grade Silicone" just in case you undo the zipper with your teeth.
papakb
1,196
San Jose, Ca
The military used to issue beeswax in a paper wrapped like an overgrown crayon. Worked wonders, cheap, and available almost anywhere.
Kurt
