Stock M715 cutting off
Knottofs
White Level, NC
I have a All Stock M715, I just on the farm. It has a brand new distributor, wires and plugs, fuel pump and carburetor.
[FONT=&quot]I need it to sit there and idle at times. After about 5-10 minuets of idling, it cuts out and will not start. After about 20 minuets she fires right up like everything fine, I can drive it all over, but when I stop and let it sit and idle again, she cuts out again and the scenario starts all over. All I can figure is that the coil is getting to hot and cutting out while sitting there. Have 3 new coils, have changes them all out at 1 time or another, and the same thing happens every time. I need this thing to run, when I need it. How do I go about changing to a civilian distributor, coil, wire's and plugs? If I need to convert down to 12 volts, so be it. What do I need? Brands, stock numbers whatever, any info would be much appreciated? Also can the M715 starter operate on 12 volts? Thanks, Captain Jack[/FONT]
NDT
5,997
Camp Wood/LC, TX
Make sure the vent lines to and from the ignitor are connected and venting. Maybe the carb is flooding because the fuel level is creeping up in the carb bowl. I seem to remember there is a rubber o-ring around the float needle housing which cracks and allows the level to climb.
