Stock single-piece military 6 lug wheels?
simp5782
Feo, Fuerte y Formal
9,346
Mason, TN
They are a3 trailer wheels. Will fit the deuce. Just never seen what weight rating the wheels are. I would assume they would be heavy rated with a 10r22.5
juanprado
2,898
Metairie/La (N'awlins)
The one on the right is a newer one piece wheel that I have seen retro fitted on m149 water buffalo's and gen set trailers in current use that use the deuce pattern. Observed on many military trains as I live in a major conversion of various railroad lines.
The one on the left I have also seen on some trailers other than m105a3. I think the military is trying to get away from lock rings on the remaining rolling stock with old school deuce pattern.
tobyS
833
IN
The budd rim is like this;
The bolt holes look different on the ones you have pictured. The first appears to be hub pilot and the second stud pilot. I don't know about their interchangability...but assume it works. Edit....on closer look, the first photo seems to have a bevel, so must be the stud pilot.
There is also a 19.5" (below dual) and 17.5" budd (see A1 above) and for reference a bolster/M1061 rim (16.5") in one piece.
