Stowage Mock-Up
jonesal
Mission Specialist
69
Brookings, SD
Here is how I'm planning to add some stowage to my MM923. The case is a leftover from adding the battery relocation kit. I had a couple of ammo boxes so I picked up the rack to mount them. The last thing was the tow bar. I'm out of space on the truck where to store things and this is what I thought might work "well". I tried mounting the tool box under the bed near the rear axle, but could not make it work.
I'm looking for some critique before I drill any holes. I'll obviously swap out the wood 2x6 for c-channel steel. The set up does not interfere with the drop side and side loading.
Any thoughts? Good or bad...
Thanks,
Al Jones
Brookings, SD
juanprado
2,877
Metairie/La (N'awlins)
The under bed solution offered by those military guys for the tow bar won me over. I ordered a kit and waiting for it to come in. THey convinved me it was rock solid. 2 bolts through the rear collars and one bolt through where the pin goes to both legs. The mounts straddle both storage rods for the bows.
I can shoot pics when I get the kit.
jonesal
Mission Specialist
69
Brookings, SD
If I read your message correctly, I will lose my bow stowage, correct? I don't want to lose that as I have the cargo cover off most of the time.
Al Jones
M923
bikeman
501
Ft. Bragg, NC
Only thing I would say with your setup is: If you are hauling stuff (anything big, blocky or heavy) you may have issues getting to the tow bar if you break down. I don't know what your access/ability is to get in from the cab side of the box. Just my $0.02 on concerns, beyond that? it looks great!
73m819
319
gainesville, ga.
only thing i would say with your setup is: If you are hauling stuff (anything big, blocky or heavy) you may have issues getting to the tow bar if you break down. I don't know what your access/ability is to get in from the cab side of the box. Just my $0.02 on concerns, beyond that? It looks great!
ditto
jonesal
Mission Specialist
69
Brookings, SD
Thanks for the comments. Unless I hear any fatal flaws, I'll be drilling the holes this weekend and finding some C channel.
Al Jones
M923
