Strange electrical problem
usmc81301
Bayfield CO
I just replaced all the harnesses about mid last year and all has been working well. A couple days ago while driving the marking lights and taillights went out but everything else works just fine. I have head lights, turns signals, panel lights and brake lights. The problem is that I can't drive at night when the tail lights won't glow. I have went down each line with an ohm meter and all seems to be well. I am out of ideas and looking for some expertise from all of you.
P.S. I did look at the wiring chart and pin schematics
dilvoy
25
San Francisco, Ca.
When weird stuff happens, check the grounds. Maybe make a ground harness from every ground wire to the battery, because the aluminum body might not have good conductivity through the body and rivets joining the body panels together.
3,075
:ditto:
Just for an experiment, clip jumper cables to the - side of the batteries and then to a clean spot on the frame and body then see if things work.
usmc81301
Bayfield CO
Thanks for all the advice. I will give these things a try. Still wired that everything works and has worked fine and it is just this couple lights not working. At least it works good in the day.
Augi
42
SF Bay Area
All the lights you mentioned are on the 'parking lights' circuit. It would make sense if the light switch went south and is not supplying power to that circuit.
Augi
papaydsailor
Pomona, CA
have that problem all the time on mine and mostly its a grounding problem. aluminum with the harness wire is not a good conductor combination plus combined with dirt and vibration all the time. i run a direct wiring all the time on mine on groundings.
