Strange fuel leak at front of Injection Pump
ZZ4x4
Sachse, TX
I've got a fuel leak on a recently acquired 6.2 that dumps a lot of fuel (like a small river) down the engine valley. The fuel appears to be to be dripping from from the bottom of the injection pump flange where it meets the front engine cover. It's not coming from the plunger or shaft seals. It doesn't make sense to me because a driveshaft seal problem should dump fuel into the crankcase. How is fuel coming out where it is?? There is no weep hole up there right? Any ideas?
Thanks,
Jeff
ZZ4x4
Sachse, TX
Well, I got in there with a small mirror and confirmed the fuel was coming from the very front of the housing. The rest of the pump is dry including around the shaft seals. I went ahead and pulled the injection pump and sure enough there is a weep hole at the very bottom right up next to the mounting flange. Looks like the driveshaft seal is leaking badly. Actually it's good there is a weep hole, since otherwise the fuel would have been pouring into the crankcase. Guess it's time for an injector pump rebuild.
MYM998
Virginia
Ok. Mine is leaking at what appears to be between the pump and the front 3 bolt connection point. I put the correct gasket on. If fuel is coming from the seal area, does this mean I have the same problem?
