Strange slipping or possibly downshifting issue on M1009
231
Mount Laurel NJ
I'll report back once I get the chance to start tearing into it. I called a trans shop, and they kept saying a bad governor would cause a no shift or very poor shift situation, and a bad sprag would cause 2nd gear problems. And a vacuum modulator would have poor shift patterns. Not sure if they are totally right but I guess it wouldn't hurt to try a new vacuum modulator, of that doesn't work, then look at the governor, and if that's not it, my clutch pack is likely toast it seems. I'll see how it goes and will report back. Still, any other advice is appreciated!
rustystud
3,392
Woodinville, Washington
I would bet money on it being the intermediate clutch pack which includes the sprag. If the sprag went it would take out the clutches. There is only 3 there. On most TH400's there is only two clutches in the intermediate clutch assembly. You can buy the special "Blue Alto" clutches and machine the hub to allow up to 8 clutches there. I have seven in mine and the 32 sprag unit. I don't want my second gear freaking out on me !
