Think I should speak up since my name's in the title?
Forgot that the towbar on the M108 was down. So I'm lining it up, go to pull forward, and the darn truck won't move. Check the ebrake and try again, and it still won't move. Goes just fine in reverse. Then Gimpy noticed the towbar was down. It digs right in going forward! So if you need a really good brake for forward, and in the dirt, the towbar WILL stop the truck when it digs in.
Dropped the pan on the motor to check the rods/mains/ and bottom of pistons/cylinders. Everything looked good, with no play in the rods. Slight back and forth play on the crank, which is normal. Filled it full of oil, installed a starter, hooked up slave cable, then fixed/installed some lines.
Was cranking the motor over with no fuel attached, 30 seconds at a time, till we had oil pressure. Truck started up on us, seems the injector pump still had some fuel in it. Ran up to about 2000 rpm for 3-4 seconds, then ran out of fuel. Oil pressure shot up about 60 psi in that short time. Sounded good, just scary that it tried to run away. Turns out the lever inside the shut off housing was stuck.
On the shut off lever, we were able to get the bar/lever inside the shutoff housing to move, but it was stubborn. Didn't get it freed up all the way.
Got a lot done, and gimpy's got his truck with good motor. So it was a good day!
Dennis
