randini
- 6
- 0
- salt lake/utah
I drained the oil last weekend, and installed Spin-on filters (thanks Jatonka!). I could not remove the rear Oil plug. I used a cheater bar on the ratchet, and ended up rounding the corners on the drain plug. I ended up removing it with a huge pipe wrench. I cleaned it up with a file, and it seems ok. I bet someone ran the drain plug on with a air gun. Anyone run into this before (where you could not remove drain)? I also put a fiber washer on. The drain did not come with a washer?
