Stuck oil filter HMMWV
4x4nutz
103
Mico, Texas
Was using a tooth wrench to remove an oil filter on one of my humvees (a new purchase) and all the wrench does is poke holes in the filter. I know I can tear the filter apart and get it out that way. Anyone know an easier route? thanx.
Just answered my own question: Lol...just pounded a screw driver right through the side of the filter and out the other side and twisted it out....
gringeltaube
Staff Member
2,275
Montevideo/Uruguay
I've resorted to the screwdriver trick a few times. It works, but is messy.
... But there is an "advanced" screwdriver trick - with absolute no mess at all!;)
Look in the scrap bin; all you need is a 5-6 ft leftover piece of PVC-insulated copper wire, something like a 2x4 mm² (12 AWG)
I learned this trick from an old ex-Navy mechanic who mostly had worked on the big Detroits: really a zero-cost, poor man's tool and still more effective than any filter wrench in the world; I guarantee...! Ever since I adopted it, I laugh about all those fancy inventions called Oil Filter Wrench...
Double that cable in the middle; wrap it around the object, twice (as pictured); stick a screwdriver/lever/small pry-bar in there and start turning while keeping some tension on the loose ends. Surfaces need to be clean (oil- & dust-free), that's the only requirement, really.
gringeltaube
Staff Member
2,275
Montevideo/Uruguay
... And to completely avoid such a "stuck filter" situation there is one more little trick (this one I learned by myself): every manufacturer in the world tells you to put (engine)oil on the seal before screwing on. Well, don't do that; use silicon grease (= dielectric grease), instead.
I bet you will notice the difference, next filter change! 2cents
papakb
1,186
San Jose, Ca
Get a large socket that will fit the oil filter adapter and remove the whole assembly then you can do this job on the workbench.
frank8003
4,978
Ft. Lauderdale, Florida
gringeltaube comments with the wire is good and the engine oil vs the silicon grease too. After changing hundreds of filters on jet engines {heats locks them up as per design} so I drove my square drive screwdriver thru the bottom or side {lowpoint] to drain and once thru both sides to get enough torque to unscrew them.
On my truck and all the cars I had a bunch of strap wrenches and other means, I tossed or sold all that old school stuff and in 2005 I finally bought a wrench, sort of like "Channel locks" and it has been used and used and used and has NOT failed to get a filter off of anything.
Everybody I have loaned it to, I standby when others use my tools so I get them back, Soon goes and buys one.
I paid big bucks as it just "came out" but now they are cheap and even at Wally World.
Milcommoguy
2,120
Rosamond, CA
Oil 60 PSI on the very best of days. Not 500. Like when was the last time one fell off ?
Righty tighty... But NOT that tight. CAMO
Karl kostman
848
Fargo ND
I have had 3 trucks that the military had changed the oil on and whoever put those filters on must have figured out a way to put a cheater bar on the filter wrench. I had two of them that I had to (like you) punch a screwdriver through and twist them that way, extremely messy PIA but I got the filters off!
gringeltaube
Staff Member
2,275
Montevideo/Uruguay
...it has been used and used and used and has NOT failed to get a filter off of anything.
Don’t know about jet engines… but I have had cases where you simply don't have enough space all around- or sufficient free angle to comfortably turn a wrench, or pair of pliers.
Advantages of that improvised "cable"tool: a) there's only one handle/lever needed; b) it doesn’t have to go-on perpendicular to the rotation axis and c) it can be re-positioned indefinitely, mm by mm, if needed.
So it still does the job even if there was very limited room and the screwdriver could only be moved a few degrees, at a time.
Besides that, one and the same thing will work equally well with a wide range of diameters. Can't do that with regular "professional" wrenches...
