goldneagle
- 928
- 113
- Slidell, LA
I have been having problems starting my wrecker. We managed to start it up at Jeff's place and get it home. When I tried to move it today it would not crank. I thought it was the battery switch because the gauges would not come on. I decided to try a different black box that I had as a spare. It seamed to be the issue. With the replacement black box the instruments panel powered up. I was able to run the starter to try and start the engine.
I think there is a fuel line problem since it was not starting. I tried several tiles and she would not start. She was cranking. When the batteries were low she barley turned then stopped. I use a slave cable to connect to my M1008. Even with the jumper cable it would not crank. So I decided to put in better batteries. Had them hooked up and still no crank. I could hear the relay clicking when I used the start switch. No crank.
With the switches on i tried to use a screw driver to jump between the small screw near the engine and the large screw with the Positive cable from the battery at the solenoid. Just a little spark but no crank.
That was as far as I got. Any help would be appreciated.
