kassim503
- 3
- 0
- Stony Brook, NY
So the 1009 is throwing another hissy fit again, this time with oil pressure. I dunked her in @ the SS Rausch Creek Rally last weekend pretty good. (Pics & video in another thread) After that we noticed 0-1 psi on idle, scooted it back to the campsite and flat towed it home where it recieved an oil change, using 15-40 mobil delvac, and one of those junky fram filters. Cold pressure is decent, 30-45 psi, about 5 psi lower than usual. But once it heats up its right back to 0, reaching about 20 running faster. The idle is accompanied with lots of lifter noise, and the sounds of me in a panic ![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
Im gonna run down to wal mart and see if I can snag a new filter before they close, try changing filters again.
I think the real problem isnt clogged filters or anything, this came out immediatley after the dunk. I dont think the pickup screen is clogged, pressure is great cold, and I parts washed it just a few months ago. Also the oil pump gears where regapped at the same time. Does the 6.2 have the tendency to break pressure relief valve springs in the oil pump?
That I didnt take apart out of fear the roll pin might eject itself later, the piston for the relief valve moved fairly easily with a screwdriver when I had it apart, almost too easily (push it down with tip of fingernail easy)
