zeisshensoldt
- 0
- 0
Let's begin this by saying I've been driving the truck nearly most the day in 90 degree 100% humidity weather, if that matters. I would guesstimate a total of 60 miles. A lot of brake usage, stop lights, etc. 4 engine shut off's and 3 starts in total for today. Everytime I made a stop I would check for leaks under the truck. I noticed a leak at the primary fuel filter so I tightened that up, but then noticed another leak on the other side. It appeared to be the fuel injector pump, but I'm not absolutely sure. The final leak occurred when I was idling my truck for it's final shutdown. After the 10 minute idle I cut the engine and disabled all the electronics. I did my usual walk around and noticed a quickly developed oil puddle underneath. I inspected, but couldn't determine if it was seeping from in between the crank case and transmission or running down from the oil pan. I let the truck sit for an hour and then rechecked the suspected oil leakage spot and it appeared to have ceased dripping for the time being, but it looked like part of seal or rubber-ish material was hanging down between the crank and trans(picture below)? I have taken pictures and circled where it's dripping from. I also uploaded a video, which I will post on here as well.
Deuce leaks - YouTube
